Audacity Menu
Jump to: navigation, search
The Audacity menu only appears on macOS. It includes some commands which are in other menus on non-Mac systems, plus some menu items which are generated by the operating system.
About Audacity
Has the same version, credits, build and license information as at Help > About Audacity on other operating systems.
Preferences
Has the same choices as at Edit > Preferences on other operating systems.
Services
This is a system-generated menu, including system tools like Finder and Disk Utility. Its exact contents will depend on what applications the user has installed and what services they provide.
Hide and Show
  • Hide Audacity:
Hides Audacity and all its windows without minimizing into the Dock.
  • Hide Others:
Hides all applications other than Audacity.
  • Show All:
Shows all applications and their windows.
Quit Audacity
Closes all project windows and exits Audacity, as at File > Exit on other operating systems.
