Extra Menu: Play-at-Speed
Jump to: navigation, search
The Extra > Play-at-Speed menu provides commands for manipulating the Play-at-Speed Toolbar and for moving between labels.
Play-at-Speed Once
Play audio once at a faster or slower speed
Play Cut Preview-at-Speed
Combines cut preview and play at speed
Normal Play-at-Speed
Play audio at a faster or slower speed
Decrease Playback Speed
Each key press will decrease the playback speed by 0.1.
Increase Playback Speed
Each key press will increase the playback speed by 0.1.
Adjust Playback Speed
Displays the Playback Speed dialog. You can type a new value for the playback volume (between 0 and 1), or press Tab, then use the left and right arrow keys to adjust the slider.
