Extra Menu: Selection
Jump to: navigation, search
The Extra > Selection menu provides commands for changing the Snap-To settings, and for extending and contracting the selection.
Snap-To Off
Equivalent to setting the Snap-To control in Snapping Toolbar to "Off".
Snap-To Nearest
Equivalent to setting the Snap-To control in Snapping Toolbar to "Nearest".
Snap-To Prior
Equivalent to setting the Snap-To control in Snapping Toolbar to "Prior".
Selection to Start  Shift + Home
Select from cursor to start of track
Selection to End  Shift + End
Select from cursor to end of track
Selection Extend Left  Shift + Left
Increases the size of the selection by extending it to the left. The amount of increase is dependent on the zoom level. If there is no selection one is created starting at the cursor position.
Selection Extend Right  Shift + Right
Increases the size of the selection by extending it to the right. The amount of increase is dependent on the zoom level. If there is no selection one is created starting at the cursor position.
Set (or Extend) Left Selection
When playing or recording, sets the left boundary of a potential selection by moving the cursor to the current position of the green playback cursor (or red recording cursor). The selection can then be drawn by using "Set (or Extend) Right Selection"(below).
When stopped, increases the size of the selection by extending it to the left. The amount of increase is dependent on the zoom level. If there is no selection one is created starting at the cursor position.
When playing or recording, sets the right boundary of the selection, thus drawing the selection from the cursor position to the current position of the green playback cursor (or red recording cursor). This is a quick way to mark a selection for future editing while playing or recording. Selections can be labeled while playing or recording using Edit > Labels > Add Label at Selection or shortcut Ctrl + B.
When stopped, increases the size of the selection by extending it to the right. The amount of increase is dependent on the zoom level. If there is no selection one is created starting at the cursor position.
Selection Contract Left  Ctrl + Shift + Right
Decreases the size of the selection by contracting it from the right. The amount of decrease is dependent on the zoom level. If there is no selection no action is taken.
Selection Contract Right  Ctrl + Shift + Left
Decreases the size of the selection by contracting it from the left. The amount of decrease is dependent on the zoom level. If there is no selection no action is taken.
Move to Previous Label  Alt + Left
Moves selection to the previous label.
Move to Next Label  Alt + Right
Moves selection to the next label.
