FAQ:Playback
Jump to: navigation, search
>  Forward To: FAQ:MP3 export problems
<  Back To: FAQ:Recording - How To's
|< Index of Frequently Asked Questions
Troubleshooting
Why have I lost sound after connecting a USB device on Windows?
When you connect a USB audio device to a Windows computer, it may automatically become the "default" device that is normally used for both playback and recording. If the USB audio device is not meant as a playback device for the computer (such as a microphone, turntable or tape deck) you may lose sound in Audacity or in most applications on your computer. You can fix the problem as follows.
Right-click over the Speaker icon by the system clock, choose Sounds, then click the Playback tab. Then right-click over the speakers or headphones device you are using, choose "Set as Default Device" and click OK.
For a more detailed walk-through of the above steps for Windows (or if that does not work for your version of Windows), see Windows: accessing the Windows Sound controls.
Alternatively, you can disconnect the USB device from the computer after you have finished recording.
Note: To hear audio while you are recording, ensure "Enable audible input monitoring" is "on". This can be toggled on/off by clicking Transport > Transport Options > Enable audible input monitoring.
back to top
Why does playback go quiet when I record or adjust the recording volume?
You may notice this on Windows, for example when recording overdubs while playing an existing track. This system setting turns down or mutes other sounds when audio goes through the recording or playback devices set as "Default Communication Device" in Windows. This feature can be useful when making or receiving Internet phone calls but is undesirable for other audio. To turn off this adjustment:
  1. Right-click over the Speaker icon by the system clock then choose Sounds
  2. In the dialog that opens, click the Communications tab
  3. Underneath "When Windows detects communications activity", choose "Do nothing" and click "OK"
  4. On the Playback and Recording tabs, you can optionally right-click over a device and set or unset it as "Default Communication Device."
If there are other problems with audio inputs or outputs not interacting properly, make sure your sound device has the latest drivers specific to your particular computer model and operating system. The drivers should be obtained from the motherboard or computer manufacturer's website, or if not available there, from the sound device manufacturer's website. For more help. Also note that Skype can sometimes manipulate playback and recording levels when it is running, even if not being used.
See also:
back to top
Why do I hear clicky playback on Mac?
This is most likely to occur if you use Soundflower or an external USB or FireWire playback device rather than the built-in audio output. The problem can usually be fixed by opening Audio Settings Preferences and adjusting the "Buffer length" setting which also affects playback. Reduce the setting to 0 milliseconds. If playback breaks up or does not start, increase "Buffer length" in increments of 10 milliseconds until playback is smooth.
Sometimes running other audio applications while Audacity is running can cause clicky playback in Audacity. This might be the case if you are running another audio editor, Apple Music/iTunes or QuickTime Player.
If you are playing a recording that you made in Audacity and the clicks are at the same place on every playback, you may need to redo the recording at the lower buffer settings.
See also:
back to top
Why is there a very low level hiss on exported files?
Deliberate low-level noise is normally added when you downsample to a lower sample format, for example when you export from a project at default 32-bit depth to a 16-bit WAV or AIFF file, or when you run effects on a project containing 16-bit audio. The additional noise is known as dither and is generally beneficial. Dither prevents clicky noises which might otherwise occur due to not being able to accurately represent 32-bit values in a 16-bit format.
If you still want to turn dither off for all data processing (including export) you can do so at "High-quality Conversion" in Quality Preferences. Alternatively you can turn dither off just for the export step. This may help avoid cumulative dither noise if you are exporting regularly over the same file.
back to top
How can I pause playback so I can edit there?
Audacity cannot apply effects or change the audio while playback is paused. To stop playback and set the editing cursor where you stopped, it is easiest to press X on your keyboard to "Stop and Set Cursor" (if there is a selection region, X trims the left edge of the selection to start at the stop position). Use either Space or X to restart playback from the stop position.
Note that except for Scrub or Seek playback, using Space or the Stop button The Stop button to stop will leave the editing cursor where playback started - probably not what you want.
You do not always have to stop paused playback yourself. If you have a selection region, you can still access many menu items when paused and Audacity will stop playback so as to apply your change to that region. If there is no selection region, Audacity will stop playback but will warn you that no audio is selected to act on.
There are many other alternative workflows, depending on your purpose. Here are two examples:
  • Instead of stopping at each edit point, keep playing and use Ctrl + M ( ⌘ + . on Mac ) to add a label when you hear each point of interest. After stopping, click in any label to set the cursor there for editing.
  • While playing and listening for an edit region, use [ on your keyboard when you hear the start of the audio you are interested in, then press ] when you hear the end of the audio of interest. The ] shortcut draws a selection region from the point where you pressed [ to the point where you pressed ]. Now you can press Space twice to easily stop playback then play that selection.
You can change any of the above shortcuts in Keyboard Preferences.
See Navigation Tips for useful ways to find the audio you want to edit then mark points or regions for cutting.
back to top
How can I play or export multi-channel (surround sound) files?
Audacity can export multi-channel files by enabling "Use custom mix" in Import / Export Preferences. You will need to adjust the mapping of tracks to channels in Advanced Mixing Options according to the channel order of the format you are exporting to, though some files or playback software/hardware might not necessarily respect that order.
However Audacity playback is currently limited to mixing down tracks to mono or stereo (two channels). Therefore playback will only reach two channels of the device unless you configure the device to duplicate audio to other channels. Many playback systems also have optional "bass management" where you can route the bass signals in a stereo signal to the low frequency channel for the subwoofer speaker.
back to top
