WavPack Export Options
Jump to: navigation, search
WavPack is a completely open audio compression format providing lossless, high-quality lossy, and a unique hybrid compression mode. For version 5.0.0, several new file formats and lossless DSD audio compression were added, making WavPack a universal audio archiving solution.
For details pleas see wavpack.com
What you hear by previewing with playback prior to export is what you will get in the Exported audio file.
Accessed by: File > Export Audio then choosing WavPack Files from the Format dropdown menu.
Audio Options
Channels
Sets the number of channels for the exported audio file. There are three options
  • Mono: single channel
  • Stereo: stereo pair with left and right channels
  • Custom mapping: use this to export multi-channel (surround sound) files or to make customized assignments between Audacity tracks and the channels in the exported file.
Sample Rate
Sets the sample rate for the exported file. Default setting is 44100 Hz, which is CD quality.
Quality
Four options are available:
  • Low Quality (fast)
  • Normal Quality - default
  • High Quality (slow)
  • Very High Quality (slowest)
Bit Depth
Three options are available for bit depth:
  • 16 bit - default
  • 24 bit
  • 32 bit float
Hybrid mode
Hybrid mode provides all the advantages of lossless compression with an additional bonus. Instead of creating a single file, this mode creates both a relatively small, high-quality lossy file that can be used all by itself, and a "correction" file that (when combined with the lossy file) provides full lossless restoration. This means never having to choose between lossless and lossy compression.
Bit Rate
This is only available when Hybrid Mode is selected.
There are options from 2.2 bps to 8.0 bps. The default is 4.0 bps.
